spike99
Nov 21, 2013Explorer
For my RV/TT's underbelly, I didn't over analyze the situation.
For my 2006 Jayco TT, I simply:
- Removed the underside coroplast (hard plastic) layer.
- Removed its soft fabric layer.
- Removed its water holding fiberglass batt insulation.
- Replaced its underside fabric heat duct pipes with real metal flex pipes.
- Installed its wiring within plastic wire loop and created smooth round corners - before securing wire loom to underside floor.
- Removed its thin 12 gauge linear brake wiring.
- Installed new thick 10 gauge STAR design brake wiring.
- Taped shinny plastic on areas that don't need over spray.
- Using wood, created access door under tub's gooseneck pipe.
- Using landscaping plastic fabric (from home hardware store), used staple gun and duct tape to apply between tank's gap. Thus, stopping spray foam getting between floor and tank gap.
- Called Spray Foam company and they sent over their mobile truck.
- The guy crawled under my TT, applied spray foam CC @ 2.5" - 3" thick
- I did after inspection - for their completion Sign-Off.
- I then removed over spray plastic areas myself.
Since I did before and after prep work myself, the spray foam company gave me a huge discount. And with their mobile truck, I didn't have to tow my RV/TT to their shop location either.
For water protection, I can then re-install the previously removed soft fabric sheet. And for even more water protection, I could re-install previously remove coroplast plastic sheets as well. Same water layer protection as factory build.
If (and if) a wire needs to be replaced or a tank needs to be replaced, I simply crawl under the RV/TT, find each end of the plastic loom piping and fish new wires. Or, cut around the plastic barrier around each tank, then remove the tank. Or, access the tub's gooseneck piping via trap door.
If you feel risk of replacing underbelly wiring is too high, simply install PVC electrical piping and where needed, use smooth 45 - 90 degree elbows and secure to underside floor. Then, fish wiring into these new 1/2" or 3/4" support pipes. Then, spray foam over the PVC piping. If wires need to be replaced, simply fish new wires down the much smoother PVC pipes (instead of corrugated wire loom plastic wire covers).
For my 2006 RV/TT, I never regretted spray foaming its underbelly. re: - click here - Today, they now make Spray Foam that is fire rated. And, its Closed Cell formula is much better (compared to formula I used 4 years ago). And when my RV's inner roof cavity and/or its inner walls need repair, I'll be using Spray Foam in these locations as well.
For me, replacing factory fiberglass batt with Spray Foam Closed Cell was very low risk / very easy solution. No brainer in my books.
Hope this helps..
Hope this helps..
