Campfire_Time
Jul 07, 2014Explorer
There is lots of missing information. You'll need to know towing capacities, tongue weight, GCVW, cargo capacity of your truck among other things. Those specs can vary depending on gearing, engine, etc. Your owners manual, your original window sticker, and the tire load specification label in your door should be able to help you determine those things. From there you can determine what weight you can realistically tow. What we call half ton series trucks cannot generally tow up to their rated capacity when it comes to travel trailers. In other words, if the tow rating is 10k#, more likely a travel trailer will max out the tongue limit and payload several thousand #s below the max rated tow capacity.
That said, there are lots of great trailers that can be towed by that truck. It's going to all boil down to personal opinion. What I consider the "best" trailer may not even come close to what you want. You'll have to get to some dealers and just start browsing as you figure out what to get.
Have fun!
Have fun!
