jaycocreek wrote:
In 2008 the Ford F-150 payload started at 1480 lbs then went clear to 3080 lbs, depending on model.
As mentioned the ones with over 3,000 pound payload are standard cab special order models. The OP stated that he wants seating for four adults. The chances of him finding a used F-150 that seats four and has a payload over 3,000 pounds is about as likely as finding Flight 370. With most 3/4 ton models having a gvwr over 9,000 pounds, why search for a maxed out 1/2 ton that has 8,000 pounds, if he needs a pickup with that kind of capacity?
