lawrosa
Oct 02, 2014Explorer
Page 76 here states 110 psi @ 4540 lbs. load range G..
http://www.firestonetrucktires.com/pdf/Fstn_DataBook_2013_HiRes_r3.pdf
Dont make sense. If your going to say air them down to 95 psi then you should have got load range F's.. You would air them down to say 80 psi. But try that with the G,s you have and IMO you will generate heat..
You really have too much tire for the truck compared to your rear axle limit which was probably based on the original tires..
So the rear axle is not the 10k as you stated its 6K.....
