LarryJM
Jan 06, 2017Explorer II
Terryallan wrote:
Easiest way. Put jacks on both sides (fore, and aft)of the tires, and take the weight slightly off the suspension. If any weight is left on the suspension. It will still bounce.
ALMOST 100% correct, but 99% of your suspension bounce is removed when you take a little more weight off the suspension than what the weight from any occupants are inside. You don't really have to remove "ALL" the weight off the suspension.
Larry
44,069 PostsLatest Activity: Jul 06, 2026
