briandunning1's avatar
Jun 09, 2018
Better LP-only fridge?
We have the standard little Dometic 3-way fridge in our Starcraft 10RT popup. We only EVER use the gas, as we only do remote dry camping. The fridge is never cold enough and worse it's unreliable, frequently going out and very hard to light or relight -- you probably know the drill.
I've searched around online and haven't found a better option. Is there such a thing as a dedicated LP-only compact fridge that might be colder and more reliable than the Dometic?
  • Might need a 12 volt computer fan installed in the upper cavity / vent to force the airflow through the backside.
    I think I'd be putting in a Danfoss compressor fridge however. You'd be amazed how well they work.
  • Pop-ups need good ventilation. Make sure there is not a void on the top by the upper vent.
    There is not much better LP fridges.
  • Nope. But have you cleaned the burner,chimney and other stuff? Those little refers seem to be very reliable. As an alternative you could use a 12v compressor refer
