Boatycall wrote:
I recently did a LOT of reading about brake pads due to an issue I was having with my '01 F350 DRW. The issue is now fixed, but this article was extremely helpful. Takes "Waddaya think of these pads" opinions and guess work out.
There is an actual friction coefficient rating that pads are rated at, regardless of organic, semi-metallic, ceramic or carbon-metallic.
Worth noting, I had chosen EBC G-rated pads @$200/set, but before purchasing, problem was found and fixed.
Brake pad coefficient ratings explained
What was the problem that got fixed ? Perhaps it would help the OP and others .
