campingwiththor's avatar
Nov 16, 2021
Big Foot Truck Camper NO taillights. Any ideas?
My truck camper tail lights are not working. No break light, no turn signal etc… however…the running lights ALL the way around the camper are all working AOK.
My truck break lights and turn signals are working fine.
Any idea on what would cause ALL camper break/turn signal lights to be off?
Could it be the master power cord running from the camper to the bed of the truck? Possible corrosion or?
Thanks for your help!
  • Test the power on the plug.
    I had similar problem on 2000 F250 and it was faulty ground.
    Ford runs heavy ground wire from the plug and bolts it to mid-frame. Some corrosion and no more current.
  • Some trucks have separate fuses for truck lights and trailer/camper lights , check them if you have them . More likely corrosion in the male or female plugs from truck to camper . Take apart and clean .
