- RCMAN46Explorer
buddyIam wrote:
A dyno can not measure HP. It only measures torque and RPM.
Look up what a chassis dynamometer is and how it works. This is the most common dynamometer you will find used in the field.
It does not and can not measure torque directly. The torque is calculated. - buddyIamExplorerTurtle
If you are making 1000 ft lbs of torque at 100 rpm you are making 19.04 HP.
If you could make that RPM 2000 and the same 1000Ft lbs you would be at 380 HP on your bicycle. You would most certainly need to have a system of torque management for your peddles.
I will say this again. A engine makes it's greatest power at the point of a graph where the product of Torque and rpm is the greatest.
You can not measure HP. It is only a mathematical equation. A sales pitch. - buddyIamExplorerBasically HP is acceleration, torque is twisting power, Your highest HP will be at the point of a curve where the product of RPM and torque is the greatest.
Torque times rpm equals power. To compare that to a real horses power you have to divide by the constant 5252.
To rate yourself in elephant power you would have to make an estimate of how much power a elephant makes, make the calculations the same as Watt did, and replace the 5252 constant with your new elephant constant.
The 5252 number is not exact. It's just a number that is used in all HP calculations. It was a steam engine salesman's pitch to sell steam engines. - Turtle_n_PeepsExplorer
Sport45 wrote:
buddyIam wrote:
Turtle
For the last time Torgue creates HP. :D
Link
Right, torque is measured and HP is calculated from it based on rpm. (I'm not quite sure what torgue does. :))
So HP is the indication of how fast the engine can apply torque. A high torque engine will get the load to the top of a hill without doubt. To get to the top faster all you have to do is increase the HP. ;)
At least someone gets it! :B
BuddyIam I can make around 200 ft/lbs of torque when I get on a bicycle. (over a 1000 ft/lbs though gear reduction)But only about a 1/2 HP. Think I would make a good towing engine? After all, I can make more torque than a Cummins! :B - buddyIamExplorersport45,
Torque times rpm equals power. To compare that to HP you have to divide by the constant 5252.
The 5252 number is not exact. It's just a number that is used in all HP calculations. It was a steam engine salesman's pitch to sell steam engines. :D - buddyIamExplorerrjstractor,
You brought up my dilemma. I sure would like the manual for the exhaust brake coming down steep 2 lane mountain roads. Coming down hill I run into a great many 10 mph hairpin turns up in the Sierras. Giving up the power to get it burns my butt. :B
To get out of the valley were I live there is a good amount of steep interstate grades. It sure would be nice to have the extra power for those.
I always end up thinking safety on the steep mountain downhill should be my priority.
But that limits me to only the Ram. Even worse power in the 4500's and 5500's. - Sport45Explorer II
buddyIam wrote:
Turtle
Link
So HP is the indication of how fast the engine can apply torque. A high torque engine will get the load to the top of a hill without doubt. To get to the top faster all you have to do is increase the HP. ;) buddylam wrote:
The difference in HP could be the result of higher RPM of a very small amount.
Now if the Alison first gear was very low compared to the Ford and Ram. The DMAX would create a great deal of torque in first gear that might lead to a initial lead that might be insurmountable within a 1/4 mile.
I'll say it a different way. Something stinks.
Either the tests are faulty.
The Dmax is under rated.
The Ford and Ram are over rated.
None of the 3 above have anything to do with my sisters or hookers.
It appears the customer is being deceived in some form. That is what concerns me.
Something that no doubt is a factor is torque management. I don't know how exactly the computers manage it, but you can almost guarantee that none of those trucks have full torque available in first gear. If they did they would need huge driveshafts and axles to avoid drivetrain damage at the hands of a driver lacking common sense. I imagine that is why the Ram Cummins with a 6 speed manual is derated quite a bit from automatic models. I'll bet a software change or two could up the hp and torque to the same as an automatic, but the driver would have to have brains enough to not drop the hammer in low gear with a 20K trailer in tow!- buddyIamExplorer
- JIMNLINExplorer III
Well, no mention was made of the fact that the Ram got 30,000 pounds to the top of the hill in one trip. To get the same weight up, the others would need two trips. As a business person that would be a huge added expense.
Being the fastest in a drag race times don't help folks in the hauling business.
I frequent several hauling forums and threads like this generate little to non comments other than which new truck has the biggest RAWRs and which truck can operate at the lowest cost per mile and last the longest before nickle and dime costs get to high.
However these type treads on a RV website are a hoot :) with the many entertaining comments/rants and interesting theories.
44,053 PostsLatest Activity: Jan 06, 2022
