Z-Peller
Sep 09, 2018Explorer
Pull the blind up and facing the window reach up and grasp top rail and twist it towards you. The rail is just held up there on clips. If you can’t get it twisted out then press your head against the glass and look up under valance with a flashlight to see clip edges on rail and use a flathead screwdriver to pry the clips open and rail will fall out. The vallance has the visible corrner brackets at the bottom srewed to the wall, and up under valance about 4 screws up into the overhead cabinet. Press your head against the window again with a flashlight and look for the screwheads. The scews will be on window side of the blind rail. You may have to feel for them with your fingertips. There will be one near each corner end that are harder to find. They will be Robertson head screws. (Square screwdriver)
