BlueCoyote wrote:
... You are correct - the rear bulge was from the rusty screws pulling out of the 3/8 plywood they used as a backer when the two halves were screwed together. Cure was to pull out the bad plywood an used some quality 1x2 wood. Also used a few 1/4-20 bolts and big washers. Had to do this on both sides and the rear to Bigfoot #2 and #1. Wound up drilling new screw holes between the existing screws and new screws along the entire side. ...
Did you have to gut the TC to put the 1x2 in place? Do you have photos?
BlueCoyote wrote:
... As for a fridge, still shopping CL and may step up to an Amish core. And that new Atwood helium fridge looks interesting for the $. Two areas that really need to work well are the fridge and AC to keep my wife comfy.
I had the coil replaced in mine in 2005. I went with a local rebuild. It has worked without flow since then. I considered a new/newer fridge, but in talking to the guy, he suggested I stay with what I had. No $100 Dinosaur board to go bad, manual propane, 120v and 12v. Minimal things to go wrong and no parasitic load on the TC battery. I believe he was correct. The fridge is not automatic, and I know how to turn the knob on the controls.
Wayne
