StirCrazy
Jul 25, 2023Moderator
notsobigjoe wrote:StirCrazy wrote:
I am not sure what you are talking about as the fiberglass is done in a mold and not a wood bonded product. I got to watch them build the shell of one camper when I was at the factory, and it is all fiberglass. do you have a picture of what you're talking about?
Not being Snarky Stircrazy just adding to your point. I looked up fiberglass camper delamination repair and found only crack and fraying of worn fiberglass repair but nothing else. I did remember that Gordon did a factory tour and here is your point.
https://www.truckcampermagazine.com/factory-tour/glass-secret-under-the-bigfoot-shell/
not sure what you're getting at. Like I said it is not construction like Luan in a normal rv. the foam insulation is glued to the interior panes then they are just glued as one to the fiberglass shell. it's not a lamination process. maybe I'm not understanding what the issue is as when a normal fiberglass laminated trailer delaminates you see bubbles in the exterior. in the bigfoot this won't happen as it is a solid fiberglass and gel coat shell with the interior glued to it.
