d3500ram
Feb 16, 2017Explorer III
KevinHatfield wrote:
... E-rated 17" tires, ...
I have researched the heck out of 17" wheels and tire because that is what I have on mine. Basically from what I have learned is that there is very little for high payload capacities. Forget the "letter" ratings when it comes to weight carry abilities... not all "E" tires are the same. You need to go by Load Index(LI). Most stock 265/70/17 are LI 121 (about 3200 lbs). I have stepped up to a 285/17 with a 126 LI giving me a little over #3700
Wheels are another matter. I do not believe anyone here has been able to determine a wight capacity for them. A safe assumption is that factory wheels are rated no less than the tires that wrap them.
You have a decent truck, but even if you go to a better LI, most likely the wheels will be the weakest link.
