gbw
Feb 17, 2017Explorer
I run my bigfoot listed below. Was on a 2500* dodge before I got my 3500* megacab. Both trucks have done well. The 2500* had super springs and handled the camper well. I upgraded to the megacab for kid room in the back. Handles fine, added airbags, upper stableloads and a sway bar. Its a heavy camper though - you'll probably flirt with close to 4000lbs. I had Nitto 126LI tires on both trucks, made a big difference.
* I despise these terms. They're 1 spring difference in the older makes of Rams. You'll find some readings here that there is really no difference between the two and you can make a 2500 into a 3500 if you don't mind being "overloaded" according to GVWR.
