StirCrazy
Mar 26, 2020Moderator
eou_edu wrote:
I am aware of the 2 piece fiberglass construction of these campers. But fiberglass itself needs structure.
fiberglass its self is structural when you get the right thickness for the application. problem is it is heavy and expensive. that why you used to see glass over wood construction and so on. the bigfoot and such I would expect the only reason there is wood in them is to have something to fasten to with out having to drill into the shell.
Steve
