unbob's avatar
unbob
Bigfoot camper - spray paint color match?
Is there an "official" Bigfoot camper white color code (or other designation) I can use to match my 2006 white-colored camper?
I've tried several but so far none match exactly.
Any suggestions? TIA
  • Big Foot campers aren't paint.. they are jel-coat. ask Bigfoot which color white they were using when your camper was manufactured.
    Why does it require a repair?
  • You already had some good advice for getting the colors matched. A professional paint shop will be a good choice and a fiberglass shop even better.
    A word of warning. You will find that the camper is not all the same color. Fiberglass does not age / discolor at the same rate. On my NL I polled some window trim and on one side it was a little whiter under the trim than the fiberglass around it and on the other a lot whiter. Also I have seen a lot of fiberglass campers repainted and the ones that I saw LOOKED HORRIBLE!!! The paint was not as glossy and it peeled.
    I have been told to do it correctly you need to sand, paint and top coat. Again I would hit up someone that deals with fiberglass to verify before you start.
  • There are better places to do color matching than Home Depot. We've never had them get a color right yet.
    I'd try an autopart/boating store that deals with fiberglass if that is what you are trying to match. They have a lot of colors which you can put in a a sprayer.
    Another option, call Bigfoot for advice.
  • if you take a piece of your camper to home depot they can scan the color and make you a match.
