notsobigjoe
May 15, 2022Nomad III
TxGearhead wrote:
My Bigfoot has been sitting in my backyard "storage spot" unused for about 2 years. I had a fabric type cover on it, but it developed a light mildew. I hired a woman to polish and wax it a couple months ago. She didn't know what she was doing. I got on top of it yesterday with a pressure washer to get the black crud off it. It had a lot. I used Mr. Pink soap in a foam cannon.
Anyway, yes I had black streaks that my 2800# pressure washer couldn't remove. Hopefully compounding it will work.
edit add: seems I heard someone somewhere say that RAIN-X will clean the Bigfoot windows.
Be careful on the roof with a power sprayer. Use a light setting like 1500 PSI to remove the crud. I had one so bad once that I used a 3000 PSI setting and literally blew the white off the rubber roof. I had to reapply the white top coat after. Lots of work but wow what a job.
Also OP, A Random orbital will do wonders with a light pad and some soft grit and won't take off your wax. Like I said more work but way better finish. The gutters completely remove the problem and invest in some extension gutter ends to drain the water away from the camper.
