TxGearhead
May 15, 2022Explorer II
notsobigjoe wrote:TxGearhead wrote:
My Bigfoot has been sitting in my backyard "storage spot" unused for about 2 years. I had a fabric type cover on it, but it developed a light mildew. I hired a woman to polish and wax it a couple months ago. She didn't know what she was doing. I got on top of it yesterday with a pressure washer to get the black crud off it. It had a lot. I used Mr. Pink soap in a foam cannon.
Anyway, yes I had black streaks that my 2800# pressure washer couldn't remove. Hopefully compounding it will work.
edit add: seems I heard someone somewhere say that RAIN-X will clean the Bigfoot windows.
Be careful on the roof with a power sprayer. Use a light setting like 1500 PSI to remove the crud. I had one so bad once that I used a 3000 PSI setting and literally blew the white off the rubber roof. I had to reapply the white top coat after. Lots of work but wow what a job.
Also OP, A Random orbital will do wonders with a light pad and some soft grit and won't take off your wax. Like I said more work but way better finish. The gutters completely remove the problem and invest in some extension gutter ends to drain the water away from the camper.
Bigfoots don't have rubber roofs, except older 3000 models. The top is gel coat fiberglass just like the sides. There is no roof to side joint, it just rolls from roof to wall.
I've had pretty good luck with a Porter Cable random orbit with 3M Marine Fiberglass Restorer and Wax, Chemical Guys pads or a twisted wool pad.
