notsobigjoe
May 15, 2022Nomad III
TxGearhead wrote:notsobigjoe wrote:TxGearhead wrote:
My Bigfoot has been sitting in my backyard "storage spot" unused for about 2 years. I had a fabric type cover on it, but it developed a light mildew. I hired a woman to polish and wax it a couple months ago. She didn't know what she was doing. I got on top of it yesterday with a pressure washer to get the black crud off it. It had a lot. I used Mr. Pink soap in a foam cannon.
Anyway, yes I had black streaks that my 2800# pressure washer couldn't remove. Hopefully compounding it will work.
edit add: seems I heard someone somewhere say that RAIN-X will clean the Bigfoot windows.
Be careful on the roof with a power sprayer. Use a light setting like 1500 PSI to remove the crud. I had one so bad once that I used a 3000 PSI setting and literally blew the white off the rubber roof. I had to reapply the white top coat after. Lots of work but wow what a job.
Also OP, A Random orbital will do wonders with a light pad and some soft grit and won't take off your wax. Like I said more work but way better finish. The gutters completely remove the problem and invest in some extension gutter ends to drain the water away from the camper.
Bigfoots don't have rubber roofs, except older 3000 models. The top is gel coat fiberglass just like the sides. There is no roof to side joint, it just rolls from roof to wall.
I've had pretty good luck with a Porter Cable random orbit with 3M Marine Fiberglass Restorer and Wax, Chemical Guys pads or a twisted wool pad.
Live and learn, Thanks! I've been recon-ing RV's for a while now and it gets easier. Most people go rite in with the heavy pad and cream and it's rarely needed. Thanks for the info... I think my favorite is McGuire's 67 one step compound. It's a good cleaner deoxidizer and a great polish in one. Use with a orange pad or heavier if needed. I rarely stray from that combo. I top off with Chemical guys extreme top coat sealant. If you like Chemical guys creams try the pro polish. It's pretty much the same thing as the 67 but a bit milder. All my pads are from china.
Joe
