- Z-PellerExplorer
I just reviewed 6 years of different model years of BF brochures 2000 -2008 there are no 2500 series 9.6 listed as for short bed use ,
Bigfoot 25c9.6SB has been around for a few years...Check out Bigfoot RV brochure online...shows both 25c9.6LB and 25c9.6SB - Grit_dogTrailblazer
bigfootford wrote:
they only list 9.4 and once an 8-11 b was listed as for short box use
OOOH, where is the OP? I kind of knew this but did some assumptions.. Guess we need the WHOLE story eh?
Jim
So you reviewed brochures for 12-20 year old models and came to this conclusion?
And what story? OP doesn't have a story, just asking about that camper model. No mention of the model year, but presuming if he's asking about it then it's a model year that they did or do make that model.
You guys are too funny....bigfoot detectives!
Big foot big foot, whatchya gonna do, whatchya gonna do when they come for you....lol - bigfootfordNomad III
Jim - 54sudsExplorerI just reviewed 6 years of different model years of BF brochures 2000 -2008 there are no 2500 series 9.6 listed as for short bed use ,
they only list 9.4 and once an 8-11 b was listed as for short box use - bigfootfordNomad IIIOk, got that over with...
My 9.6 2500 weighs right at 4200lbs loaded with water, food and clothes.
My f250 is a supercab gasser and weighs 5,800 lbs. SRW. Total weight of truck and camper is 10,060.
My rear axle weight loaded is about 66xxlbs.
I have 19.5 tires and Air Lift air bags in the rear. I run about 40psi, just enough to level the truck.
Camper bought new and has been on 2 f250's. Camper has about 200,000 miles on it.
I have no other suspension changes.
Tire capacity is 4950lbs each so I have lots of reserve weight capacity on the rear of my truck.
I would check your tire capacity.. and figure that camper will weigh about 4K loaded. Decide later if you need air bags and anti sway etc.
Jim - Grit_dogTrailblazerWell those campers are piles of ____ then?
Thought BF was a good brand? - bigfootfordNomad III
Z-Peller wrote:
Original post says 9.6 short box camper on short box truck. Don’t see sagging issues with that. Old non basement BF’s had sagging issues, but haven’t heard of it with newer ones. Lots of plywood in the construction. Had my 2002 9.6 LB on LB truck for 14 yrs from Alaska to Texas to Maritimes with never an issue.
Wow, I totally missed that the OP said sb 9.6... Thankyou...
Sorry OP for missing that...
My 9.6 lb on a long bed does sag a bit. Not bad but you can see it. It is a basement 9.6 2500.
Jim - Z-PellerExplorerOriginal post says 9.6 short box camper on short box truck. Don’t see sagging issues with that. Old non basement BF’s had sagging issues, but haven’t heard of it with newer ones. Lots of plywood in the construction. Had my 2002 9.6 LB on LB truck for 14 yrs from Alaska to Texas to Maritimes with never an issue.
- Grit_dogTrailblazerAm I mistaken that Bigfoot markets “SB” models for short bed trucks?
- 54sudsExplorer
bigfootford wrote:
sound advise i have worked on many different models of BF's that had the rear sag problem.
The 9.6 BF is not built with enough fiberglass frame structure to support that much weight hanging over the rear of a short bed truck. Also center of gravity would actually reduce front axle weight. My 9.6 only puts 300lbs on the front axle..
I have a friend that has an older BF that is 11'5". Even on a long bed the rear of the camper has sagged quite a bit and caused a delimitation of the internal structure of the walls at the rear overhang. He fixed that but the sag was not much better.
My 9'6" does sag just a bit back there too and that is on a long bed. No structure problems though... 20 years, lots of miles and many rough roads! All the way to Prudhoe bay and more.
Lastly... Both the gray and black tanks are in the overhang... 50 gallons when full. Along with that part of the fresh water tank is in that last 1.5' of overhang... A short bed would place about another 2' of water weight in the short bed overhang of the camper.
The 9.6 holds about 50 gallons of fresh water...
Jim
