Ok done deal.
I installed the angle yesterday and let the adhesive cure overnight. This afternoon I ran a small bead of silicone on the exterior side of the angle.
Mowed the front yard.
By then the silicone had cured pretty good and I stuck the weatherstripping on the angle. I used 5/16" x 3/4" black foam weatherstripping. I closed the door and felt some resistance but had no way to tell if or where the door was touching the seal. So, I used some Vaseline and put a small dab in about 6 places on the door sealing area, closed the door and latched it, opened it and found 6 spots of Vaseline on the weatherstripping. Whether it is compressing enough I dont know. I'll spray it down with a water hose to check, maybe tomorrow.
