AK Truck Camper wrote:
So......
Just bought my 2000 2500 9.6 Bigfoot and its obvious the previous owner wasn't a fan of the showers.
The outside hose to the head is completely missing and the inside shower head is cracked and leaking (see the tape).
Thanks so much!
Look again. That's the hose connected to the top of the mixing valve, and the other end appears to be poking out behind the metallic shut off valve attached to the wand. That shut off valve is not original, and should not be needed since there is a shutoff in the wand.
