stevenal wrote:
Look again. That's the hose connected to the top of the mixing valve, and the other end appears to be poking out behind the metallic shut off valve attached to the wand. That shut off valve is not original, and should not be needed since there is a shutoff in the wand.
Interesting, that add-on valve probably cost more than a replacement head would have. I do remember that my previous camper’s outside shower head valve would let water leak by too! I’m going to hook up that hose and check it all out before buying another one.
Thanks!
