hedgehopper
Mar 16, 2017Explorer
bkenobi wrote:We bought the 10-2 in preference to the 9-6 because it has more headroom, more overhead cabinets, and (we think) a better layout in general. (We can sit up in bed without bumping our heads.) You might want to look at the Northern Lite website and see if you like the RR layout. We have the CD (center dinette), which we prefer (and which is similar to the 9-6), but you might prefer the RR. As I said take a look at the layouts on the Northern Lite website. The new model RR has a dry bath. But the older models have a wet bath. I'm not sure when NL switched from the wet to the dry bath. Also, the weights shown on the current website will probably be higher than the weights for an older model.
The tag says NL10-2QRR and the equipment list says 10'2". The tag says the dry weight is 2425# but the equipped weight shows 2775# so I assume that's wet as equiped?
