TxGearhead wrote:
Yeah I figured about as much. I've taken unloaded rear pressure down to 58 and it helped a little. I'll back off a little more.
You know how they repair a 12" deep pothole....fill it with 18" of asphalt and create a 6" bump.
Are you sure those are not speed bumps? :B Sorry TxGearhead, I just had to say that.
I reading this post again, I realized I misunderstood before. I though you were hitting holes. Now that I understand it is bumps, you can do a simple test. Disconnect one side of your sway bar. Drive over a speed bump at a slight angle. Connect the sway bar and go over the same speed bump at the same angle. The faster go, the more you will be determined to leave the sway bar connected.
