502_Jimmy
Mar 14, 2014Explorer
riven1950 wrote:Michigansandzilla wrote:
So to sum it up when you don't have the option of using a truck bed:
Mounting a hitch to the back of TT can cause frame fractures.
Mounting a rack over the propane tanks can cause a dent in the tailgate if you turn too hard and it's difficult to turn off the propane.
Mounting a hitch to the front of TV will drastically reduce airflow and can overheat the engine.
Mounting to the roof of TV is inconvenient and difficult but doesn't cause any major problems.
Stowing bikes in TT can cause interior damage, (I know this from experience).
Is that correct?
I think you are pretty much on with that comment. I am still thinking on this project as it could involve a good bit of money and I want to get it right. My truck is so tall I would never try to get bikes on off it. Also, I am trying to solve two issues at once. Carrying 2 kayaks AND two bicycles.
I like searfoss's pcv bike rack and its cost problem is I have a short bed with a tool box so would not work without removing the front wheels, although that may still work. going to be doing some measuring / thinking for a while.
If anyone with a short bed p/u and tool box is hauling kayaks and bikes I would be interested in knowing how, unless the bikes are on top the TV, on front of it, or on rear of TT. I know that eliminates quite a few possibilities.
For the record, I can turn as tight as I need to and access my tanks shut offs with the rack mounted and bikes installed.
John
44,071 PostsLatest Activity: Aug 30, 2026
