Lantley
Mar 15, 2014Nomad
michigansandzilla wrote:
So to sum it up when you don't have the option of using a truck bed:
Mounting a hitch to the back of TT can cause frame fractures.
Mounting a rack over the propane tanks can cause a dent in the tailgate if you turn too hard and it's difficult to turn off the propane.
Mounting a hitch to the front of TV will drastically reduce airflow and can overheat the engine.
Mounting to the roof of TV is inconvenient and difficult but doesn't cause any major problems.
Stowing bikes in TT can cause interior damage, (I know this from experience).
Is that correct?
No perfect answer here. Just like anything else, I guess we all pick and choose based on our own needs.
I can only speak for the Arvika tongue mounted rack because that is what I own. You can access LP tanks easily if bikes are not on rack. Rack folds up and tank cover can be removed as normal.
I did cut an access panel into the rear of my plastic propane cover to access tank when bikes are on rack. Cutting an access panel is a very simple effective solution to accessing valves.
I towed my TT with a Hensley Arrow hitch which gave me 12" more clearance between trailer and truck and eliminated any turning issues
44,071 PostsLatest Activity: Aug 30, 2026
