kend40
May 04, 2014Explorer
riven1950 wrote:Michigansandzilla wrote:
So to sum it up when you don't have the option of using a truck bed:
Mounting a hitch to the back of TT can cause frame fractures.
Mounting a rack over the propane tanks can cause a dent in the tailgate if you turn too hard and it's difficult to turn off the propane.
Mounting a hitch to the front of TV will drastically reduce airflow and can overheat the engine.
Mounting to the roof of TV is inconvenient and difficult but doesn't cause any major problems.
Stowing bikes in TT can cause interior damage, (I know this from experience).
Is that correct?
I think you are pretty much on with that comment. I am still thinking on this project as it could involve a good bit of money and I want to get it right. My truck is so tall I would never try to get bikes on off it. Also, I am trying to solve two issues at once. Carrying 2 kayaks AND two bicycles.
I like searfoss's pcv bike rack and its cost problem is I have a short bed with a tool box so would not work without removing the front wheels, although that may still work. going to be doing some measuring / thinking for a while.
If anyone with a short bed p/u and tool box is hauling kayaks and bikes I would be interested in knowing how, unless the bikes are on top the TV, on front of it, or on rear of TT. I know that eliminates quite a few possibilities.
check out www.bikefastrack.com this can be used above a toolbox that is flush mounted or below the box rails. It also allows the use of the majority of the box. And it can carry 5 bikes. Also looks like it is easy to remove when you are not transporting bikes. I was impressed by the videos on the site. Then with a rooftop kayak rack you might get everything you are wishing for.
44,071 PostsLatest Activity: Aug 30, 2026
