Dimac
May 26, 2014Explorer
bike rack
Looking for a bike rack that will hold at least two bikes on the back of a travel trailer...any suggestions
welove2drive wrote:
I went with the Swagman bike rack. It is one of the few that state it is alright to use on a trailer.
Swagman wrote:
Mounting the Jackknife on a Trailer or 5th Wheel:
1. Purchaser is advised that the load created by rack and bicycles will exceed the strength of trailer or 5th wheel bumper, mounting location or the bike rack. The rack is not under warranty if mounted in this location.
Swagman wrote:
Mounting the Bike Rack on a trailer or 5th wheel:
1. Purchaser is advised that the load created by rack and bicycles may exceed the strength of trailer or 5th wheel bumper or other mounting location. Failure through improper mounting will void rack warranty.
2. The recommended 14” ground clearance is not sufficient on trailers or 5th wheels. Ground clearance must exceed 15” and will vary upon application. Damage to bicycles or rack due to ground clearance problems on trailers or 5th wheels is not covered by warranty.
3. Excessive movement can cause damage to the rack or bike. This is not covered by warranty. Pull the rack back and forth and-if the rack has excessive movement a separate tether strap should be purchased.
