Pig-Smoker's avatar
Pig-Smoker
Bike racks
Anyone have any good ideas on a bike rack, need one that will hold two bicycles. I have heard good things about one that bolts to the A-Frame and I have also been told that the ones that fit the back bumper can cause problems. The one that bolts to the A-Frame I'm guessing would hold the bikes over the LP tanks. Any thoughts?
  • We did not want to put them on the bumper for too many reasons.
    What we did is used our dinette area to install the bikes.
    When you remove the seats we flipped over the wood seats. Installed the fork
    mount into the wood seats. Then in the rear put to small pipe 1/2 clamps. Secured these with bolts to the wood using T-nuts. Then put the forks in the front clamp. Used cords to hold the rear down with the clamps.
    Then repeated the process 4 times, but flipping the direction of each bike.
    Then made sure the bolts were below the wood surface so when the seats were flipped over there was not issue with the dinette seats.
  • I recently installed a Curt front mount hitch on my Expedition for the sole purpose of attaching a bike rack. I chose the Hollywood SportRider SE2 because it held the bike by the wheels, which I think makes for a lower height of the mounted bike:
    The bike rack folds up when not being used. It normally would fold to a perpendicular position, but couldn't because of the bumper. So I drilled new holes for the retaining pin to hold the rack about 2" away from the bumper:
    Bruce
  • jfkmk wrote:
    We installed a front hitch for that purpose.
    I have not thought about this , but i like the idea!
  • downtheroad wrote:
    Since you have a TT and a truck, why not the bed. That's where ours go.
    truck bed is full of other stuff
  • Ours is the 4 bike bumper one it goes in a 2 inch reciever hitch I put one on the bumper of the 5th wheel and that way we can move it to the truck and the suburban. Have had it for 3 years with no problems. 2 mountain bikes and 2 kids bikes.
  • Install a 2 inch receiver on the rear attached to the frame then use any bike rack designed to fit a 2 inch.
  • Not bike people here, but have been around long enough to know NOT to consider one that attaches to the bumper. Easiest and least $$ would be to put them in the bed of the truck unless that's already spoken for. Some folks have built racks to hold them securely either out of wood or larger PVC. Sure you'll hear more about the other types available. Happy camping!
