Turtle_n_Peeps
Feb 27, 2019Explorer
ktmrfs wrote:Turtle n Peeps wrote:
Bio D can and does retain water. It is hydroscopic. It will hide in the fuel itself.
Todays new fuel systems do not put up with ANY water. The pressures they run now days will kill the pump or injectors in a heart beat.
I do not like the stuff nor do I use it when there is straight #2 for sale.
Todays modern fuel systems cost 15 grand+ to replace. "Do you feel lucky? Well do ya?"
Do you realize that much of the diesel you buy today as "straight #2" is B2-B5? and isn't required to be labeled as such on the pump. You'd be hard pressed to find B0. You've probably run way more B5 than you might think.
"In every state, biodiesel can be blended with traditional petroleum diesel up to 5 percent. At this B5 blend level, the fuel still meets the ASTM D975 fuel specification and does not require any additional labeling at the pump. Once retailers begin to sell blends from B6 to B20, labeling is required."
I do indeed.
You do realize the original title of this thread is: "Bio-diesel/ Is it a good or bad thing for the engine?"
The OP clearly said Bio-diesel and not mixed fuels. And as you pointed out S15 has nothing to do with mixed fuels.
Two of my friends worked for CAT for 30 years. I crew chief'ed for them on their race cars. I talked to them a lot about synthetic oil and bio-diesel, DPF's and all kinds of diesel related stuff. They had all sorts of stories about "Bio-diesel." And I do mean LOTS of stories! I saw first hand what 100% BD did to a tractors injectors. He had to clean "Bio-snot" out of the fuel system. Cool hu? :B
There is a reason OEM's to this day recommend no more that 20% mixed fuel BD. Most people don't have a clue why. I do. It can even get into oil changes or in the case of BD, a lot more of them.
OP, it's really a good idea to read your owners manual and see what % of BD you can use. (at least what the OEM recommends)
If you think burning a higher percentage of BD or straight BD is a good idea, so be it. Burn away man!
44,066 PostsLatest Activity: Apr 16, 2026
