Anon_Tech wrote:
This forum won't let me upload photos directly, if you'll have a look at the post I linked in the OP then you'll see original photos, I've also made a new post showing the outlets in question.
Post in thread 'Black Series fire hazard' https://rvforums.com/threads/black-series-fire-hazard.10253/post-67512
This forum does not support direct picture hosting.
Have to use a third party online host.
Something else to consider, the combo 120V/12V panels have TWO completely electrically isolated sections.
120V is treated one way and 12V is treated as "low voltage" and deos not require things like having electrical connections in a work box or even clamps to clamp the wires.
Some of your complaints may have come from seeing wires entering the 12V section which will not have any wire clamps, no buffering of the openings and will have individual wires entering/exiting which is 100% the polar opposite of 120V wiring.
You made serious allegations of having breaker 3x the ratings which I find to be impossible and would be more expensive for the manufacturer to have done.. 3 times the rating would mean for 30A service they would have a 90A single pole breaker and for a 50A service a 150A two pole breaker.. Price those breakers.. They are not cheap..
Heck even standard outlet wiring 14 ga wire would have to have 45A single and 12 ga wire would have to be 60 singles..
None of the breaker sizes you claim to have found would be commonly found in any electrical supply warehouse let alone in a RV builders inventory.
HERE is a catalog of Murray breakers which would possibly fit in the RV electrical panels..
I am not saying mistakes can't happen, they can, but you have stated a lot of things that just seems to be a lot of exaggeration for attention..
