allmightypuff's avatar
Mar 08, 2022
black tank issue
i got an issue i cant figure out. my toiket doesnt have a water supply to it, getting 3 different toilets from 3 seperate campers, all had the same issue, noone ever pulled the flushvalve to release the pressure in the valve body and it froze and broke, so i just use a bucket and fill the bowl that way. its a 1987 trl and im not buying a 500 dollar toilet. Anyway, didnt have this problem until recently, so i suspect its related to the cold (?) but when i flush the toilet, everything falls straight down and piles up right there, water goes past into the bottom (gate valve end) of the tank, but the **** stays there, piling up until its up in the neck of the toilet. just 2 days ago i ran 3 full tanks, (30 gallon) of hot water, cleaned it all out, even stuck a snake down to verify its empty, and already its all piled up in the neck. im by myself so its not due to too many people using it, so whats the problem? last 2 days and nights since the last cleaning its been well above freezing so idk what to do, other then abandoing the toilet completly and having to drive 12 miles down the mountain to the truck stop every time i need to use the toilet, which is absurd, or literally clean out the tank every day
  • Are you leaving several gallons of water in the tank after you empty it? Are you leaving the dump valve open? When you flush it, are you using plenty of water? If the poo is hitting a dry surface it’s gonna stay there. Water water water.
