purplepossum wrote:
Like to stop the dripping leak on a short term basis while we're out. Think that this leak is the cause of problems I'm having with tank clogs. Think possibly most of the liquid is leaking and leaving the semi solids behind.
Any suggestion on products that will work under the above
conditions? Looking for a short term repair. Understand that I'll have to fix the problem on a more permanent basis when I return home.
If the leak is between the tank and the dump valve then it could be the problem with tank clogs. X2 on using radiator tape as a temporary fix.
Your dumping method could also be contributing to the problem. I use a clear connection at the end of the sewer pipe and keep flushing through the toilet with a garden hose until I see clear water coming through. Otherwise, you can get 'stuff' caught in the blade valve which will keep it from closing completely.
