ashnic's avatar
ashnic
Black tank sprayer plugged
Our Outback black tank sprayer which we hook the hose to after dumping the tanks is plugged? Working fine 2 weeks ago..now can't get any water thru..Looked at removing the line and checking but that would require removing a lot of underpinning...just wondering if anyone had any idea's..
  • I have a check valve in the inlet, identical to the city water inlet. With this check valve, I am comfortable with tossing the vacuum break out. You see, the vacuum break will leak water by design, and it won't be in my trailer.
  • Well found mine under the bathroom sink as a member had already posted. Pulled it out and the spring loaded side was stuck..Also beginning to think the campground may not have had enough pressure. Putting it back together this evening before heading to Hocking hills in Southern Ohio for what they are saying it going to be a gorgeous weekend...
