- weathershakExplorerI,m stickin with the blue stuff. My stuff just stinks so bad and easily overpowered the Geo method, especially in this heat.
- ktmrfsExplorer IIIpersonally we avoid adding any additional dish soap to the tanks. It foams up to much. However, I do add about a cup of High Efficiency laundry detergent to each tank along with a cup or so of mixed up liquid calgon to each tank. For the black tank I also put in some of the black tank stuff with the microbes in it. Then add a gallon or so of water to each tank as well
Inexpensive and it does seem to keep the tanks clean and the sensors working.
And with the microbe digester, very little odor. In fact, trailers been sitting in the driveway for a week from our last trip, temps in the 90's. and getting ready to flush the tanks, opening the toilet drain and no noticeable odor at all. - CincyGusExplorer II
odis wrote:
Why not use the little Bottles of RV toilet chemicals? Are they bad for the system?
Thanks
Jim
No, they are designed for the system. Many people use the GEO method listed above because Calgon water Softner and some laundry detergent are much cheaper, coat the inside of the tank making it too slippery for anything to stick (no dreaded mountains of pooh) and reportedly help keep the sensors working.
To answer the original Posters question, I use a cap full of calgon and approximately the same amount of powder detergent and then hold the flush value on the toilet down until I have what I estimate to be a couple gallons go down the toilet. If I know it's going to be a while before I use the camper again, I may let a little more water go down. I do all this after dumping so it can slosh around on my trip home. It sloshes again on my next trip on the way to the campground. - old_guyExplorerthe post above about using bleach, is something I heard you should not do. the bleach and urine mix into a gas that is not good for you.
- odisExplorerWhy not use the little Bottles of RV toilet chemicals? Are they bad for the system?
Thanks
Jim - gboppExplorer
- DutchmenSportExplorerJust throw some in. Doesn't matter. Anything is better than nothing. I don't know of any "rule" or formula. We pour a dishpan of dishwater soap down the toilet sometimes. (Mosly to put more liquid in it). Sometimes we toss in a cup of bleach and a couple gallons of water and drive around and then dump the bleach and rense with clean water so the bleach won't (long term) hurt the rubber on the dump valves. Sometimes we do nothing. Sometimes we drop a chemical pouch in there.
Do dishes, save the dishwater in a pan, and then toss that down the toilet. If you do that, you've got a good start. The idea is to add enough to make everything slippery.
If you want your tanks cleaned, drain them. Add 3 or 4 gallons of water. Put in a few squirts of Dawn Dishwashing liquid, little bit of bleach and then drive around for 10 minutes so it can all slosh around real good. It will break anything loose "hanging around" inside the tank and keep it smelling good.
