Click For Full-Size Image.
Not bad for 1st such job in my life. Bear in mind I did work with torches before, so did not have to learn about keeping the torch away from the skin the hard way. ;)
The 700W welding station work slow in 90F weather, so for colder weather - more powerful one would be advised.
Main difference between metal and plastic welding is that you need to apply most of the heat to the rod and push melting rod into softened material.
Put the tank to 6" of water raise test and it holds without need for additional welding.
