kw_00
Jun 14, 2016Explorer
Blackbear tune
Hey guys, Just a quick question, has anybody done the Blackbear tune to there 08 and up GM 6.0? Just wondering if you have post results if you can please. I am looking at the hand held custom tune ...
HaulinBass02 wrote:calsdad wrote:
I spent a bunch of time going thru all the tire size options because what I really want is to have the ability to add larger brakes to the truck. From all the kits I have seen - that means going with 20" rims. Which is another issue because after doing some measuring - I found that there is precious little room available in the front wheelwell for larger sized tires.
What I think I've finally decided on is that I'll go with a 20" rim - with LT285/55R20 tires. This size tire is 32.4" in diameter according to Tire Rack (vs the OEM tires which are 265/ 70R 17 which are 31.7" diameter)
That means I have around 1" larger tire - which by my measurements should just clear the front wheel well when turning. I did find some info on modifying the front wheelwell which looks like it might gain up to another inch or so of clearance. So I think I'm safe with that size tire.
I'll check out what AKCooper has done. My reasoning for going with the larger tires is simply to put in larger brakes. My reasoning for going with 4.10 is because it apparently ups the tow rating to 13k. Going to the slightly larger diameter tires may mean I need to go to a different ratio than 4.10. For the 10.5" axles it seems like the only next jump there is - is to go to 4.56.
My suburban was used and already had 20" wheels and LT285/55/20 tires on it with cranked torsion bars and shock extenders. I currently run a LT305/55/20 but will be going to a LT295/55/20 when these wear out mainly due to tire width. The current tires I have are almost 34" tall and the new size is right at 33".
I can tell you that you will need to crank the front torsion bars to get the 285/55/20 to clear. If you really don't want to do that then the only way is some pretty major trimming of the innner fender liner. I am an offroad guy so I ultimately rebuilt the front end of the suburban with a Cognito upper control arm which allows me to crank the torsion bars with an offset torsion bar key to get about 3" of lift while maintaining good alignment specs and good ball joint angles. I know for a fact that you can't clear that tire without at least SOME torsion bar cranking. I HAD an extra set of torsion bar keys and shock extenders but I'm putting them on my '99 Silverado 2500 I just got otherwise I'd let you have them.
As far as brakes, I went with a set of EBC slotted rotors and their yellow stuff pads on front and the same slotted rotors and green stuff pads on the rear and MAN, WHAT A DIFFERENCE! I really think that the factory calipers and rotor size is fine, as long as you get a quality high performance rotor and pad.
I panic stopped with the boat (no brakes, single axle) and it was under COMPLETE control and stopped well short of where I needed to. I don't know if it is any cheaper than a larger caliper/rotor kit, but I didn't really want to mess with that anyway. Worth checking out. But whatever you do, for a large vehicle, don't get cross drilled rotors, they tend to crack around the holes and don't offer as much surface area, which is something you don't want to lose. The slotted are good for cooling and venting the braking gasses away to prevent fade. Oh and I've never had brake fade since going with that setup, the slotted portion helps keep the rotors cool.
Yeah, I'm still pondering the gearing and what is best. Obviously I only want to do it once but at the same time I don't want to wish I went bigger.....my situation really has to do with, am I going to put a full lift kit on the suburban at some point and add more weight and tire to it or am I going to stick with where I'm at....I think if I stay at the 33" height (or roundabouts) then I'll be fine.
Gear calculator
I put in the numbers for AKcooper9's setup (33's, 4L80E and 4.56 gears) and played with the numbers. In 5th (my preferred towing gear) with the 6L90E, and 33's with 4.10s we equal what he was doing in his OD 4th gear. He said he was able to tow his big TH trailer around in 4th with no problem. That's my leaning....
