LEMII's avatar
LEMII
Blew Out Black Water Tank Jayco 23B
I hooked up the Flush King to clean out our black water tank, turned on the garden hose, then started doing something else. This was a big mistake! I forgot about filling the black water tank! I ran down to the camper and turned off the water, but too late, the damage was done. But I am a little puzzled about what happened.
I found the black water tank laying on the ground under the camper. It had separated from the toilet flange fitting and broke the metal holding straps. However, there was no liquid INSIDE the camper. Apparently the toilet valve held.
The black water tank has two openings in its top: one larger for the toilet and one smaller for the vent line. I do not understand why no water escaped though the vent, unless it was plugged. I'll be checking it out this weekend when I have time to work on it.
Both openings in the tank have/had rubber grommets into which the ABS plastic pipe fit. Black ABS cement was used to seal these fittings.
No fittings were damaged, so I will reassemble everything and replace the straps.
Questions: How should I prepare the plastic pipe and rubber grommet for the cement? Does the cement require any kind of activator / primer to be applied to the fittings?
Thanks.
