BTPO1
Oct 07, 2015Explorer
enblethen wrote:
The rubber grommets normally do not use any adhesive. They normally have grease to insert the pipe and then it is friction tight to prevent leaks.
When the tank bulged from excess water the straps failed. Use something better then strapping. I have seen U-strut used and angle iron.
X2, I would also use bolts and nylock nuts to hold the channel or uni-strut in place instead of screws. JMO
44,059 PostsLatest Activity: Mar 18, 2026
