machunt
Feb 27, 2020Explorer
block heater
i have a 2013 chevy 1 ton dually, doesel of course.  after plugging in my block heater over night, it seemed hard to start.  up untill now everything seemen fine.  i do have 120 volts at my plug in.
ktmrfs wrote:ScottG wrote:machunt wrote:
can we just stay on topic, all i want to do is check my cord or my heater its self to see which is bad. and i dont have a fancy plug with a element on it. just a simple 3 prong male plug
ON the first page, 2003Silverado gave you the answer.
Plug it in and look for a spark as you do so.
Are you not getting a spark? If you are, it's working.
But if no spark , doesn't mean it isn't working!!!!!
for the 2003 that works. For later models, not a good indications. Somewhere between 204.5 and 2015 GM added a thermostat in the block heater circuit so it won't turn on above a certain temp, somewhere around freezing. So the plug in and check for a spark above that temps is going to head you in the wrong direction!!!!
