dave17352's avatar
dave17352
Explorer II
Nov 22, 2015
Blow out or Use the pink stuff my personal review
Okay I did the blow out the air lines thing for the first time. I have
a large air compressor and everything necessary to make it as easy as possible. Took me about a 1/2 hour. If I were to do it again it would take about 20 minutes.
Then because I am paranoid I ran the pink stuff through. The pink stuff took about 5 minutes and I have nothing to be paranoid about. It also has a lubricant in it which is good for the valves and pump.
I should say I do believe the air got all the water out. It to me is just so easy to use the pink stuff and so safe I believe that will be my choice in the future. I did spend the 6 dollars on pink stuff for two gallons. But that seems like a small cost for the ease and convenience.
Now of course I have a winterizing valve and water heater bypass. If I did not then the air would be a more appealing option.
JMHO
