Nvr2loud
Nov 04, 2013Explorer II
westend wrote:
How did you come out on this nvr2loud? I was thinking about this, you may be far enough North where any ice would be hard to melt. I bet a half liter of Vodka introduced into the system would do the trick. If it works, you can celebrate with the other half.
I need to replace my bypass valve, it does not always switch position when I turn it....
All summer long I had the bypass open since I don't use the hot water tank, and no issues with water flow through the bypass. We took the trailer out for a Halloween trip and used the hot water heater so I had to close the bypass valve. When I reopened it, it stayed in the closed position. I got it to open now, but will replace it in the spring.
