Coffee_GrinderExplorerOct 17, 2016Blowing out water lines prior to winterizingHow do you purge the water lines and p traps for winterizing. Not sure where the air line connects .
Johno02ExplorerOct 17, 2016Also make sure that you pour enough antifreeze in the traps to run down into the dump valve lines.
Related ContentBlowing out water lines for winter storage.Winterizing tankless water heaterBlow out winterizing questionWinterizing tips and tricksBlow out water lines question
