cullivoe
Aug 05, 2014Explorer
Blowing tires
Our trailer has blown 3 tires in the past year. All on the same wheel, the right side front axle tire (it has two axles). The first time this tire blew, the whole tread came off, and chewed up the whe...
downtheroad wrote:a bad bearing, will heat, but when they do, it is a short distance to total failure.Tom/Barb wrote:
Have you ever stopped and checked the temps of the tire and wheel during a trip?
I'd have the axel alignment checked too, does the that tire wear faster?
500 miles on a tire, there is something really wrong. brake dragging ?
I agree...also you might have a bad bearing in that wheel that is causing the wheel/tire to heat up excessively.
