cullivoe
Aug 05, 2014Explorer
Blowing tires
Our trailer has blown 3 tires in the past year. All on the same wheel, the right side front axle tire (it has two axles). The first time this tire blew, the whole tread came off, and chewed up the whe...
B.O. Plenty wrote:wear pattern on the tire will tell you that quicker.Tom/Barb wrote:There's more to it than that...What about camber and toe in or out?? Anyone that has worked around an alignment shop will tell there's more to an alignment than just tracking which is how square the axles are with the frame. You need to check all three axises to get the wheels truly aligned..B.O. Plenty wrote:
RV dealers don't have the equipment/expertise to that. B.O.
It only requires a accurate measurement of the distance from the hitch to the center of the axel on each side of the trailer.
a simple comparison of the distance will tell you if you have a problem.
B.O.
