cullivoe
Aug 05, 2014Explorer
Blowing tires
Our trailer has blown 3 tires in the past year. All on the same wheel, the right side front axle tire (it has two axles). The first time this tire blew, the whole tread came off, and chewed up the whe...
goducks10 wrote:Tom/Barb wrote:
I would eliminate the axel position ( out of line) because that usually causes problems with both tires on that axel.
Not always true. When I had alignment problems only one side was affected. The axles won't move. It's the ends that get out of alignment. You can hit a pot hole or curb with one tire and it will be the only one affected.
