Our trailer has blown 3 tires in the past year. All on the same wheel, the right side front axle tire (it has two axles). The first time this tire blew, the whole tread came off, and chewed up the whe...
All of the discussion focus has been on the axle. What about the wheel/rim? If the same tire has always failed has the same wheel always been put back in the same place? If a rim is losing air then the tire will overheat and fail. It would probably also be flat when parked, but it is still something to consider.
