Our trailer has blown 3 tires in the past year. All on the same wheel, the right side front axle tire (it has two axles). The first time this tire blew, the whole tread came off, and chewed up the whe...
Tires:( After you get the axel checked, consider going to a tire with a higher load rating. If you use "C" , go up to an "E" rated tire. If possible go to a 16 inch rim.
