PHM4LR
Mar 07, 2016Explorer
Per Sway Pro instructions, ninth chain link from the end opposite the u-bolt should be inserted into the slot of the latch. You may have to use the tenth or eleventh link from the top depending on conditions. The shank can be inverted (long end up/down)to raise or lower the front of the trailer. Check the sticky in the towing section for a discussion on whether the vehicle should be level or how much rise you should get on the front.
Good luck, and enjoy your hitch.
Pat
Pat
44,068 PostsLatest Activity: Jun 21, 2026
